Help Pages > Broadband > Hardware Setup Guides > SpeedTouch 516v6 1-Port Router - Setup Guide
Connection
Keywords: Thomson | 516v6 | 516 | | hardware | router | setup | broadband Summary: A Guide to setting up the SpeedTouch 516v6 1-Port Router.
  1. Before you begin
  2. Connecting Microfilters & Cables
  3. Connecting to your Computer
  4. Connecting to the Internet
  5. Troubleshooting
  6. Advanced Settings
1. Before you begin
This guide will take you through setting up your SpeedTouch router from scratch and applies to both Windows and Apple OS X systems.
Check the label on the bottom of your router and make sure it says ST516v6 in the top left corner (pictured below). If the label on your router says ST510v6, you need to follow the ST510 Connection guide.
ST516 label
Make sure your broadband connection is up and running before you set up your router - we'll email you when it's ready.
Your package contains:
Contents
  1. Ethernet cable
  2. SpeedTouch ST516v6 router
  3. Power supply
  4. Setup guide
  5. Microfilter
  6. Broadband cable
[Top]
Microfilters
Microfilters look small and unimportant but they’re essential for keeping your phone and Internet services from interfering with each other. Without microfilters you'll see poor speeds and connection drops
  • Plug a microfilter into each telephone socket that's used at your property
  • If you had to unplug something you can plug it back into the Phone socket of the microfilter
  • If you need more filters, you can order them from us or buy them from most electrical or computer stores
  • See our Guide To Fitting Microfilters if you need more help with this
Cables
  • Plug the grey broadband cable into the microfilter socket marked ADSL
  • Plug the other end of the cable into the DSL socket on the back of the router
  • If you've received a 2-part power supply (as in the picture above), clip the pins onto the adapter
  • Connect the power supply and switch the router on with the power button at the back
The Power light will turn red at first and the DSL light will flash - wait until they've turned green (and stopped flashing) before continuing.
[Top]
Follow these steps to get the SpeedTouch router connected to your computer.
  1. Plug the yellow Ethernet cable into the Ethernet socket on the back of your router
  2. Plug the other end of the Ethernet cable into your computer's Ethernet socket
  3. The Ethernet light on the front of the router will now light up - move onto the next section, Connecting to the Internet
[Top]
Automatic Connection
  1. Once you've connected the 585v7 to your computer and switched it on, leave it for about 5 minutes. The Internet light will turn green by the time you come back - go to Step 2.
    If the Internet light does not turn green after 5 minutes, go to the next section.
  2. On your computer, open a Web Browser (such as Internet Explorer or Safari).
    • If you see your homepage and you're able to browse then you're connected and you don't need to do anything else - congratulations!
    • If you're redirected to the Broadband Setup page (pictured below), go to Step 3.
  3. Enter your Username & Password (the ones you use to log into this site), choose your provider and press Go. Shortly after, you'll see a confirmation screen shortly afterwards and you'll be able to start browsing.
Broadband Setup
The Internet light is OFF or Flashing after 5 minutes
  1. On your computer, open a Web Browser, such as Internet Explorer or Safari. You'll see The SpeedTouch welcome page. Click Set up my SpeedTouch and go to step 2.
No welcome page?
If you don't see the welcome page or you get a page cannot be displayed error, type http://192.168.1.254 into your browser's address bar and press enter on your keyboard.
You'll be taken to the SpeedTouch home page. Click SpeedTouch on the left menu. When the page has loaded, click Set Up which is under the Pick a Task... list and move on to step 2.
Welcome Page
  1. The Easy Setup wizard will open in a new window. Click Next.
Easy Setup Page 1
  1. On the Service Selection screen, choose Plusnet and click Next. Only choose Other if you want to use No-NAT or other advanced setup options.
Service Selection
  1. Type in your Broadband Username and Password and click Next.
Username Screen
  1. Finally you'll see a summary screen. Have a quick check through the settings to make sure everything is correct. Use the Back button if there's anything you need to change. Press Start to finish the setup wizard and connect to broadband.
Summary
After about a minute the Internet light on the router will go green and you'll see a confirmation screen. Click Finish.
That's it! You're connected to Broadband.
[Top]
Troubleshooting
Resetting your router
If you have any problems with your router, you can return everything to the default settings by using the reset button.
Make sure you have note of your broadband username and password before you start Use a paperclip, pen or pointed object to press into the reset pin hole on the back of the router. Keep the button pressed in for at least 7 seconds. When the power light goes red, release the button and wait until the power light turns green again.
You now need to apply your settings again. Follow this guide again from Connecting to the Internet.
Your router's lights
Here we'll explain what the different lights on the router mean:
Power Status
Off Router not powered, check power cable and button
Red Router is starting up, should turn green after a short while
Green Router is powered up
DSL Status
Off No DSL cable connected. Microfilter or phone line problem
Blinking Green Router is attempting to connect to the local telephone exchange
Green Connection is OK
Internet Status
Off No device connected
Green Device connected
Ethernet Status
Flashing Green Device sending / receiving data
[Top]
Advanced Settings
The SpeedTouch 516v6 includes a built in firewall and other advanced features.
To control these features; open your web browser and enter http://192.168.1.254 in the address bar. When the router home page has loaded, click Toolbox.
[Top]
This page last updated 5th August 2009
Rate this page
happy   neutral   unhappy
Has this page helped you solve your problem? Your feedback helps us to improve the help we provide.
Please note: We cannot reply to individual feedback through Rate My Page. If you need more help with a problem please use the Help Assistant. Other customers will be happy to help you with most issues at the Community Site Forum.
Sitemap
Products
Business Solutions
Member Centre
Community
Help & Support
About Plusnet
